leaking oil
Old Dec 27, 2009 | 09:26 PM
pullacowonaski's Avatar
Default leaking oil
hey i have a problem i changed my gaskets a few days ago and i think some where its leaking i checked all around the gaskets and no oil
maybe its from before because its not smoking anywhere but there are four drops on the ground so idk any ideas people
Old Dec 27, 2009 | 09:39 PM
A4 2000's Avatar
The only way to know for sure is to remove the belly pan and see exactly where it's dripping from. It's probably best to clean the engine too and then check everywhere with a flashlight.
Old Dec 27, 2009 | 09:43 PM
yeah i will have to do that
Old Dec 27, 2009 | 11:01 PM
bbboy's Avatar
Member
Could also be some oil left in the pan or around the engine. Unless you wiped averything off after you did the gaskets.
Old Dec 27, 2009 | 11:12 PM
i hope so
Old Dec 28, 2009 | 01:08 AM
DÌEGØs AÜD!CTIØN's Avatar
what gaskets did you change??
my 2.8 used to leak oil from around the valve-cover (it wasnt enough to leave any drops but it would just burn off) I changed the valve-cover gaskets a few months ago and it helped alot but it still leaks a bit from behind the left side...im guessin its the cam seals on mine and maybe thats what's going on with urs too....
Tirrany2000
Sep 2, 2008 08:26 PM
Jc61990
Aug 22, 2008 11:48 AM
darkminotaur
Jan 3, 2008 11:51 AM
Bryceaudi
Jul 31, 2007 03:42 AM
Dudek12
Jan 21, 2007 07:23 PM
