leaking oil
hey i have a problem i changed my gaskets a few days ago and i think some where its leaking i checked all around the gaskets and no oil
maybe its from before because its not smoking anywhere but there are four drops on the ground so idk any ideas people
The only way to know for sure is to remove the belly pan and see exactly where it's dripping from. It's probably best to clean the engine too and then check everywhere with a flashlight.
what gaskets did you change??
my 2.8 used to leak oil from around the valve-cover (it wasnt enough to leave any drops but it would just burn off) I changed the valve-cover gaskets a few months ago and it helped alot but it still leaks a bit from behind the left side...im guessin its the cam seals on mine and maybe thats what's going on with urs too....
Bryceaudi
Jul 31, 2007 03:42 AM
