LED reading HELP ME!!!
Old May 31, 2010 | 02:37 PM
Scaryfatkid's Avatar
Question LED reading HELP ME!!!
As many B5'ers know, our LED's burn out. I was driving today and my car beeped at me and a new image was displayed on my LED panel. The image looks kind of like a a set of parenthesis inside another set of parenthesis. Has anyone seen this image before or know what it is?
Old May 31, 2010 | 02:48 PM
chocalotstarfish's Avatar
Super Moderator
Check you lights, sounds like the light indicator. Tail lights, break lights ect...
edit: could also be ABS light but it would say abs in the circles... wear senors is just a (O) if nothing else, damn audi warning lights all look the same! You're not by chance a chinook are you?
Old May 31, 2010 | 02:50 PM
srlito's Avatar
almost sounds like the brake wear sensors (O)
Modulemaster.com for the led fix w/ lifetime warranty
Btw: i see your from MN what part. I grew up in Grand Forks, ND
Old Jun 1, 2010 | 12:27 PM
I am assuming that the wear sensors are just sensors in my brakes that tell me when to replace the pads, right?
When I bought the car a month ago, the dealer had put new brake rotors and calipers on, I am assuming new pads as well, but I did buy it from a dealer, so I will have to make sure they didn't cut anymore corners on the car. (You may remember my clutch thread)
If the pads are intact, what should I do?
BTW I am from the Rochester area
Old Jun 1, 2010 | 01:45 PM
edepaolo's Avatar
@ srlito modulemaster.com has the fix for the bum LEDs? mines been broken since i got the car
Old Jun 1, 2010 | 04:13 PM
srlito's Avatar
edepalol - Yes they do for about 150 or so.
Scaryfatkid - if the pads are intact check the line running off the pad its possible that its shorting out causing the fault to show up.
Old Jun 1, 2010 | 04:17 PM
srlito's Avatar
http://modulemaster.com/en/services/...t_clusters.php
Link to the instrument cluster repair. There temporarily out of stock though.
AudiCross
Apr 16, 2010 04:15 AM
Yerfdog006
Mar 17, 2007 08:19 PM
A4_1.8_20v
Jan 10, 2006 01:24 AM
Hecareth
Apr 2, 2005 05:24 PM
blades
Oct 8, 2004 09:04 AM
