License plate light problem
Old Sep 17, 2008 | 06:28 PM
benzodiazepine's Avatar
Default License plate light problem
Has anyone had a problem with their license plate lights? Mine are out, and it doesn't seem to be due to a fuse or bad bulbs, but possibly some sort of bad connection between the contacts for the lightbulbs in the light assembly itself, or some other wiring problem. The only time theyve worked since I tried replacing them was once after I slammed the trunk. One of them came on, but when I opened and reclosed the trunk, sure enough, it went off again.
Old Sep 17, 2008 | 06:43 PM
CRAZYHAWK's Avatar
Unscrew the 2 plastic lenses. Sand or file the metal contacts.
Turn the parking lights on. Replace one of the lights making sure
it lights. Bend the metal as needed. Do the same for the other light.
Turn the lights off.
Old Sep 17, 2008 | 06:45 PM
Redrum1's Avatar
Mine blew a bulb and I replaced it. Had the same problem as you. Unplug the light and remove the whole assembly. get yourself some 600 grit sand paper and clean the contacts where the plug fits and also sand clean the contacts that hold the bulb. When its all cleaned up put the bulb back in and put the plug back on. turn on your parking lights and check to make sure its working. It should be working at that point if you cleaned it good enough. If not disassemble it and clean it right this time.
Good Luck...
Old Sep 17, 2008 | 08:40 PM
Just did that, and it worked beautifully. Thank you so much.
Old Sep 18, 2008 | 06:52 PM
allintherims19's Avatar
had the exact same problem then i cleaned up the contacts. They were a real pain in the A$$. I would like to just replace them with knew ones but cant find any...if anyone has a link to where i could buy them?
Old Sep 18, 2008 | 07:23 PM
Dallas09's Avatar
Theres a writeup and i think the guy bought new ones from the dealer... so moderatly expesnive for that part im sure. I just used a dremel and sanded them they work great now.
pbrules10
May 14, 2011 05:22 PM
dtkelley2005
Mar 31, 2009 02:48 AM
bongeunchung
B7 Models
Feb 24, 2008 12:54 AM
winks2
Nov 26, 2007 09:36 PM
