Little help
just picked up a 2001 a4 2.8 quattro never owned an audi before and so far very very impressed just had the timing belt done the rest of the car is extremely clean and just two minor issues the drivers door handle from the inside is loose and when i had the windows tinted this week the guy said there wasnt anything wrong and he couldnt figure out why it was lose and my other problem is the info screen in the middle of the cluster it works and says push in clutch to start car and everything but when driving it does not come on like it did when i first got it but i know it still works how do i fix this?
thanks for the help love audi already.....
first off, use some periods, damn!
1. i guess the door handle being loose is a common problem. saw a thread about it once and it said a spring most likely busted. not a tough fix.
2. does the cluster work at all? like are there any pixels lit up? if it turns off try turning it on manually by pressing the button on the underneath portion of the winshield wiper lever. it should say reset.
