Look What I Did!
ORIGINAL: manufan
What kind of problem were you having with drilling the aluminum?
Next time, try drilling a smaller hole first and then the size hle you really want. Or, start by using what's called a center drill, they come is a bunch of sizes and drills a small pilot hole and a countersink at the same time. they might not be too easy to find though. Better off to just drill the smaller pilot hole. Use some sort of coolant or light oil on it too. Aluminum will take a pretty high rpm. If you care, 4(cs)/d. A typical cs(cutting speed) for aluminum with a hss drill bit would be 200.
ORIGINAL: redleg6
excellent work, wish i had your skills when i owned my A4 (or at least the time and patience)
ORIGINAL: 01A4T
We should hope they work better the first time as apposed to your lowers
.........I kid, I kid
.But whatever, I have fogs now!
