Loookin for people running a Forge 004
Old Feb 15, 2008 | 11:58 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: Loookin for people running a Forge 004
you have an 01, you could do the diode mod out of my sig for much less.
Old Feb 16, 2008 | 04:55 AM
  #22
NuYorka103185's Avatar
ORIGINAL: CIA
Ok, im convinced. I will order one right away. I hope i will not become a cop magnet with this sound and if it gets on my nerves i know who's to blame.
/me looks at NuYorka103185
Hey don't blame me, I'm the guy who did 24 hrs in jail for a criminal speeding ticket, leave me outta this one haha
Old Feb 16, 2008 | 12:31 PM
  #23
CIA's Avatar
CIA
no no, i need somebody to blame for my expenses
I guess this will be the fast way to 'suicide' my turbo quickly and get something bigger. Ill blame NuYorka103185for this, afterall he's the bad influencehere. ahahah
Old Feb 16, 2008 | 03:12 PM
  #24
cincyTT's Avatar
I'm make believe
If you really think running the same boost as everyone else really kills the turbo, wow, just wow. The turbo can do 18-22psi daily for years and years. It hardly effects the life of the turbo
Old Feb 16, 2008 | 03:28 PM
  #25
chaos92287's Avatar
its still putting a lot more stress on it than stock a4's. but as long as you let it warm up and cool down properly, that little k03 can take a beating. you'll want a new turbo before that thing dies on you
Old Feb 16, 2008 | 03:40 PM
  #26
cincyTT's Avatar
I'm make believe
you still basically in the turbo efficiency range which doesnt matter if its pushing 10psi or 40psi, the strain wont really change in that range. Sure it spins faster, but thats what it was made to withstand. Push it out of there and thats a whole new thing. Pushing the turbo30 psi and your basically making a grenade
Old Feb 16, 2008 | 04:17 PM
  #27
CIA's Avatar
CIA
i dont know the limits of the turbo,i doassume that if i push it too far, it will give up on me.
EDIT:
so if i understand clearly, with the 1' billet plug i will have to seal one of the hoses that goes into the stock DV?
And, what spring should i use with the Forge? I believe i have a 8lb spring in it.
Old Feb 16, 2008 | 06:32 PM
  #28
CIA's Avatar
CIA
nvm i found the info
https://www.audiforums.com/m_732016/tm.htm
Old Feb 16, 2008 | 06:40 PM
  #29
chaos92287's Avatar
the 1" billet plug plugs the hole in the TIP that the recirc side of the stock dv goes to. you can either plug the hose that goes to the tip, or remove that hose completely and plug the hole in the TIP, which is what i did.
Old Feb 16, 2008 | 06:50 PM
  #30
cincyTT's Avatar
I'm make believe
ORIGINAL: CIA
THose are the magic words. It when you push the turbo out of its efficiency range where you wear down the turbo. The way to do that is by pushing over 25psi and tightening the wastegate trying to make it hold boost longer. Running 18-22psi daily is nothing for the stock turbo
