loosing boost
Old Jun 3, 2009 | 12:28 AM
jt's A4's Avatar
Default loosing boost
ok guys i have a 2000 1.8T and after 4k rpm i get no power and it doesnt get better until i shift gears can anyone help me
I ran a check and the only code that showed up was about the air conditioning could that have anything to do wit it
Old Jun 3, 2009 | 04:52 AM
silver_rings's Avatar
not sure about AC but loosing boost are known issues on these cars, had same problem in past, could not tshoot until I got boost gauge. Possible boost leak, check Vac lines. Do you hear any hissing sound while full throttle?
Old Jun 3, 2009 | 07:00 AM
ghost6303's Avatar
you need a boost gauge to troubleshoot boost issues. you dont even know for certain that you are loosing boost. the torque spike on the k03 is in the mid 3000's so once that huge spike levels off it may feel like you have no power past 4k rpm just because its smooth, and because you dont even have a chip.
Old Jun 3, 2009 | 09:20 PM
jt's A4's Avatar
i have boost guage and it shows 0 psi once i get past 4k rpm
Old Jun 3, 2009 | 09:24 PM
ghost6303's Avatar
what is it before 4k? how much vacuum do you see at idle? you probably have a leak.
Old Jun 4, 2009 | 12:39 PM
jt's A4's Avatar
its around 11 psi before 4k
Deeman
Jun 7, 2012 02:28 PM
Indiepunk
Jun 1, 2007 07:25 PM
austindgarner
Mar 28, 2007 01:32 PM
02TTs
Apr 20, 2006 01:51 AM
y2karnival
Feb 24, 2006 09:19 PM
