MAF Sensor Replacement Issues
Old Oct 26, 2009 | 02:38 PM
markwilliamsnc's Avatar
Default MAF Sensor Replacement Issues
I drive a 1999 Audi A4 1.8T FWD. It's had its share of problems.
My car's MAF sensor has slowly died over the past few months. Car went from running rich to drowning - wouldn't really run at all. I went online and ordered a new MAF sensor and then found some guides on how to clean the existing MAF sensor.
I cleaned the old sensor with rubbing alcohol, let it dry, and re-installed it. Car worked wonderfully. Had someone reset the fault so I could drive it for 50 miles and re-test for emissions. Well, about 3 miles later the check engine light tripped. I decided to just intall the new sensor.
Before removing the bottom part of the heat shield I poured water over it to cool it off (stupid, I'm pretty sure, we'll get to that). The new sensor's chip wasn't solid like the old one - it has two wires with these beads on them going through a hole in the chip. It's a third party OE part matched to the part number. Re-install the part, start the egine and the engine cuts off in about two seconds. Ouch.
I take the part back out and discover some water. Like maybe five drops. I think some might have gotten past the sensor and into the air intake. I re-install the OLD sensor and start the car. The old sensor is back to its old self - drowning the car in gas.
What do I do?
Issues:
1. Small amount of water in air intake PAST air filter. Is this a major concern? How can it be fixed?
2. Is the new MAF Sensor the right kind? 1999s are split - one sensor for 5/99 and before, another for 8/99 and after. I'm pre-5/99.
3. Should I try replacing the air filter too?
Thanks for reading this really long post and thanks for your advice. Anything is appreciated.
Old Oct 26, 2009 | 03:37 PM
redline380's Avatar
Legal Moderator
a little water in your intake isnt that huge of a deal. as long as its a couple drops i wouldnt worry about it. yes, you could have the wrong sensor. i wouldnt even mess with aftermarket at all. what i did is get a used one from local used parts dealer. as for the air filter its your choice. you could just blow it out w/ compressed air
q7jeff
Jan 14, 2014 07:15 PM
BryceHamernick
May 16, 2013 11:18 AM
jccollins0726
Jan 16, 2010 12:55 AM
munkydotorg
May 3, 2009 08:44 PM
raddox
Dec 20, 2005 07:15 PM
