MAJOR WATER PUMP PROBLEMS!!!!
Old Jul 14, 2008 | 07:44 PM
A4wolfsburg's Avatar
Default MAJOR WATER PUMP PROBLEMS!!!!
Hi all.New to this forum.My son just bought an 97 A4 Quattro 2.8 6cyl.He neded a new water pump so we bought the whole kit to do timing belt + water pump, thermostate etc....In the process of removing the water pump a bolt snapped off in the block[sm=headbang.gif] went to the local AP store they recomended a bolt extracter which of course broke off in the middle of the bolt as well[:@][:@][:@]Not sure what a sure fire method is of fixing this problem.Though one of you seasoned audi wrenchers may.....I hope. thanks in advance.
Old Jul 16, 2008 | 02:34 AM
Tweaked's Avatar
Default RE: MAJOR WATER PUMP PROBLEMS!!!!
Post a pic if possible. You're probably best off drilling the old bolt and using a time-sert or Heli-coil.
Old Jul 16, 2008 | 08:10 PM
Prizmatik's Avatar
A picture would definetly be helpful, but you will probably have to drill the bolt out and do as Tweaked suggested. [sm=signs003.gif]
Old Jul 18, 2008 | 03:38 PM
thanks for the suggestions.I decided to try something a little more aggressive.I used my mig welder to weld a fender washer to the stud then in turn weld a larger nut to the washer.Outcome was well...out it came, lol.[sm=happy046.gif]
Old Jul 18, 2008 | 05:12 PM
Prizmatik's Avatar
Well congratulations!! See, you didnt need our help after all.Great idea too. Happy motoring
Old Jul 18, 2008 | 05:37 PM
Thanks.Amazing what you do when you put your mind to it
Old Jul 18, 2008 | 05:42 PM
Tweaked's Avatar
Ah, you cheated! You didn't say you had a mig welder!
Old Jul 18, 2008 | 05:49 PM
Good thing for the mig cause I was considering dynamite, lol.[sm=wootwoot.gif]
Old Jul 18, 2008 | 06:15 PM
Lebe Frei's Avatar
haha a shop did mine and had the same problem and had to get a welding shop right up the road to get it out for them.
Old Jul 18, 2008 | 07:40 PM
If only they used never sieze these things would happen less often, of course then they wouldnt be able to charge you by the hour for extraction[sm=lildevil.gif]
bunjamins
Aug 21, 2013 12:29 AM
MetalMan
Jul 19, 2012 09:15 PM
skvchau
Jan 26, 2008 02:22 PM
audi_a3_1st_timer
Sep 26, 2007 01:24 AM
audi_a3_1st_timer
Sep 25, 2007 04:32 PM
