MDC alternative solution
Old Mar 7, 2008 | 12:51 PM
awwdii's Avatar
Default MDC alternative solution
I will probably get bagged for this butitswell deserved if so. Check out this quote below and let me know if anyone has ever attempted this.
"work with me here, lol, its an air regulator for an air compressor, we removed the w/g silanoid and replaced it with the air regulator (adjustable valve), poor mans manual boost control. We got the idea from a performance shop. Seems to be working fine, just have to watch it when the temperature lowers."[sm=proof.gif]
Old Mar 7, 2008 | 12:56 PM
chaos92287's Avatar
Default RE: MDC alternative solution
or you can just buy a real mbc. hell i just bought a turboxs off audizine for 65 shipped. you want to start experimenting and buying cheap parts, be prepared for the consequences. and if something breaks its gona cost way more than a mbc
Old Mar 7, 2008 | 01:59 PM
awwdii's Avatar
True, At least they didn't attempt use a water fauchet. There sigs would read
T3 turbo pushing 20 gpm it's sweet. lol
Old Mar 7, 2008 | 03:10 PM
cincyTT's Avatar
I'm make believe
No need to reinvent the wheel. There are plenty of cheap and expensive mbc's out that. Depending on what you want it for, there is a certian one best for you
Old Mar 7, 2008 | 05:36 PM
awwdii's Avatar
Cincy,
That turbonetics mbc you mentioned to me on another thread.Is that used with the tee or good it be used without it?
Old Mar 7, 2008 | 05:38 PM
awwdii's Avatar
ORIGINAL: awwdii
Cincy,
That turbonetics mbc you mentioned to me on another thread.Is that used with the tee orgood it be used without it?
Sorrytypo I meant could not good
Old Mar 7, 2008 | 05:41 PM
cincyTT's Avatar
I'm make believe
Not sure what you mean. Just use it in place of the n75.
Also, the edit feature is much more effective than a second post.
Old Mar 7, 2008 | 08:51 PM
awwdii's Avatar
Cool. As for the edit option yeah I probably should of opened my eyes since its near the quote button. thanks for the correction
Ilana Eidelberg Spector
Jul 10, 2012 05:26 PM
ArbitraryLife
Aug 1, 2009 11:34 PM
dkenn75
May 13, 2008 02:40 PM
moeron7
Sep 18, 2007 07:44 PM
