Misfires..
Old Sep 27, 2013 | 10:06 AM
JavanT's Avatar
Default Misfires..
Got misfires in cylinders 1, 3, & 4. My car is chipped so I replaced the plugs with BRK7E's, )gapped to .028") & changed the coil packs to the Hitachi Rev. E packs. Still getting misfires, but only for a minute or so on a cold start. Other than that my car runs in limp mode and no more misfires till next cold start. Any ideas?
Old Sep 27, 2013 | 10:47 AM
MetalMan's Avatar
How old are your plugs? I generally replace my BKR7E plugs every 5-8k miles.
How old is your fuel pump? You could try cleaning your MAF sensor to see if that would help. Maybe also try swapping one of the injectors from a misfiring cylinder to cylinder 2.
Old Sep 27, 2013 | 11:20 AM
JavanT's Avatar
Thanks for the reply. Plugs are brand new, got them a week ago. As for the fuel pump I'm not really too sure.. how could these symptoms be caused by the fuel pump?
I also read it could be the ICM, and my coil pack wire harness has definitely seen better days, but I'm trying to exhaust all options before I resort to that.
I'll clean the MAF too even though its only a year or so old so I don't think its that either, and will switch up some injectors. Will post w/ updates after work.
Old Sep 27, 2013 | 11:52 AM
MetalMan's Avatar
Your 2000 doesn't have an ICM, so rule that out. (only AEB engines do)
As far as fuel pump, I meant filter but typed pump lol.
Old Sep 27, 2013 | 12:34 PM
JavanT's Avatar
Lol I was like hm. That was one of my first guesses as well, changed that about 2 weeks ago too. When I clear my codes and start my car on a warm start (no increased RPM's for a brief period) there are no misfires and no misfires under heavy boost as well. Maybe just a slight hiccup now and then but not nearly as bad as a cold start.
Then once my drive cycle completes the CEL comes back on, and limp mode is back. With a system too lean code as well but I'm sure that my pre-test pipe 02 is shot from all the backfiring.
Old Sep 27, 2013 | 12:42 PM
JavanT's Avatar
Edit: I just had a thought, I know my valve cover gasket needs to be replaced as I had a small amount of oil on the spark plug in cylinder 2, is there a way that oil could get getting sucked into the intake causing the misfiring?
Old Sep 27, 2013 | 12:47 PM
MetalMan's Avatar
Don't think it would be enough to cause any issues, but if it's leaking then you might as well replace it anyways.
Another thought: have you replaced your CTS (coolant temp sensor) on the back of the head? And how old is your primary O2 sensor?
Old Sep 27, 2013 | 12:50 PM
JavanT's Avatar
I have not replaced the CTS. Might as well do that this weekend since I'm changing that damn flange back there.
Primary 02 is about 1.5-2 years old.
Old Sep 27, 2013 | 01:16 PM
MetalMan's Avatar
Definitely replace the CTS while you're in there!
Your O2 sensor should be fine, but if you decide to replace during the process of elimination, Amazon has it for $59:
Amazon.com: Bosch 16978 Premium Oxygen Sensor: Automotive Amazon.com: Bosch 16978 Premium Oxygen Sensor: Automotive
Old Sep 27, 2013 | 01:19 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
That's a really good price. I may have to pick one up. It's the last thing I can think of that would be causing me to average 18mpg on a stock ECU. I get 12mpg in the city.
