Mod list
Hey guys ive had my a4 for 2 years and its time to modify it now can some people make a list of what they have and post a pic up thanks
I've always wanted to make a list of what I've done but I haven't had a reason to until now :p.
Exterior - DEPO One Piece Projectors Clear Sidemarkers Facelift Euro Tails Interior - Brown Suede Rear Deck Brown Suede Headliner Brown Suede A Pillars Brown Suede Armrests Brown Suede Center Console Sticker Bombed C Pillars Facelift Three Spoke Steering Wheel Swap Lighting - 55w 5000k HIDs White LED City Lights Stealth Turn Bulbs Amber LED Sidemarker Bulbs Xenon Interior Bulbs White LED License Plate Bulbs Suspension - ST Coilovers Wheels - Mercedes E320 17x8.5 20mm Spacers in Rear Exhaust - Magnaflow 14816 Misc. - Aero Wiper Kit Fuzzy Dice Stickers Painted Tow Hook Painted Wheel Bolts I think that's about it... I'm sure I'm missing a few things. |
Nos..
gtrs turbo
tuned ecu 630cc injectors atp h/f manifold 034 tip cone filter 3 in maf forge 004 power gasket tp full custom exhaust stern mounts fmic n75 race valve boost guage s4 bumper euro rs4 headlights euro plate s4 taillights shaved lower moldings s4 wheels b5 18 in rs4 wheels wheel stud conversion a8 brake conversion(tt carriers) walbro 255 pump |
Kraut, you have a 2.75" maf fyi.
OP look at some of the peoples sigs and garages around here, you will get an idea. Plus what kind of money are you trying to spend on your setup and what power goals? You can go anywhere from a basic chip to fully built engine with a big ass turbo and all supporting mods. |
2001 1.8tq tip
Engine: K04 turbo ATP 3" Test Pipe Flowmaster 40 series muffler w/res. delete Autobahn TIP Front Mount Intercooler Greddy Type S BOV (Recirc) Turbosmart Boost Controller Cincy Diode Mod Interior: Autometer Boost Gauge Ultragauge Monitoring scanner JVC Double-Din Head Unit Suspension/Wheels: VMAXX Coilovers 18" ASA Rims 225/40 Nexen Tires Exterior: Kamei Badgeless Grill Carbon Fiber Door Trim Covers De-Badged |
1 Attachment(s)
Engine/Drivetrain Modifications:
APR Stage 1 Software Suspension Modifications: Koni Coilovers Wheels/Tires Modifications: 18" RS4 DTM Rims Interior/Exterior Modifications: Blacked out RS4 replica grill, Valeo Ecode headlights Attachment 36767 |
well this is the part where i get laughed at....
god my car is ghetto right now. im sooo not posting pics. 2001 a4 1.8t quattro (s-line????) engine/exhaust- modified B6 AFE stage 2 cold air box godspeed fmic ECS test pipe custom 2.5" straight pipe exhaust Forge 007 dv Forge manual boost controller. ECS carbon fiber engine cover (dyno proven 75hp. its true.) exterior- stock wheels coated black cause im cheap. front bumper custom removed by parking lot curb. interior- steering column boost gauge. large tear in driver seat. anyway. compaired to everyone else i feel cheap as hell. if i keep the car for a while ill be fabbing a custom intake mani, a big top mount turbo mani with a gt35 setup, some custom fmic piping and a bunch of other bitchin fabbed up parts... and then the car will be my shop's drag car. dont ask about the shop. it dont exist yet. just know we have a full machine shop already... and are working on welding equipment... myself and one other certified machinist, and a welder... though most of our collective experience is with hondas, toyotas and mazdas... so if you think my list is ghetto (and dont worry, i think its a lame list too) laugh while you still can. :D |
Originally Posted by FasterA4ThanUrs
(Post 1234728)
OP look at some of the peoples sigs and garages around here, you will get an idea. Plus what kind of money are you trying to spend on your setup and what power goals? You can go anywhere from a basic chip to fully built engine with a big ass turbo and all supporting mods. It might take me a few hrs to write all my mods down. lol ENGINE: ATW block bored to 83.5 mm ABA 2 liter crank JE 8.5:1 Pistons Pauter Rods Ported AEB head RaceWare head stud kit Schrick 252/260 cams 1mm over intake valves Stock size exhaust valves High lift, high rate valve-spring set with Titanium retainers VR6 throttle body Custom Intake Manifold 034 Motorsport Wrinkle painted valve cover 034 Motorsport Solid Engine mounts Stern Snub Mount from Pure Motorsport Custom Battery size Oil Catch Can with 3 filters Odyssey Light Weight Racing Battery mounted in trunk Custom Billet Battery Holder Custom Power Steering Cooler NewSouth Performance PowerGasket Plus 16" Aftermarket Electric Fan TURBO & EXHAUST: Full-Race.com manifold GT35R with .82 ar Tial 38mm waste gate Wastegate dump tube 3" down pipe with Turn down Custom Evolution Racewerks Race Series FMIC with Garrett 24x10.5x3.5 core 2.5" hot side IC pipe and 2.75" cold side IC pipe Tial 50mm BOV HKS Filter FUEL & TUNING: 034 Motorsport IIc stand alone with 4.5 bar map sensor 1000cc injectors Custom 034 Motorsport fuel rail SX adjustable fpr Bosch Motorsport 044 fuel pump in take Dual Bosch Motorsport 044 inline pumps and surge tank -8 fuel line from dual pumps to fuel rail HKS EVC4 Boost Controler 32psi on 110 octane TRANSMISSION and DRIVELINE: Stock 1.8 trans Custom 4800 lbs dual diaphram 6 puck clutch Billet Steel flywheel 034 Motorsport solid trans mounts Stern rear diff mount and rear diff bushings BRAKES: A8 Front Brake kit upgrade SUSPENSION & WHEELS: Koni shocks(regrooved fronts) Intrax S4 Sport springs OEM non sport front sway bar OEM sport rear sway bar OZ SL 17x8 wheels Hooser Drag Radials 225/45/17 Wheel stud conversion kit INTERIOR: Cobra Suzuka kevlar race seat Sparco Racer Steering Wheel JH Motorsports Solid Short Shifter kit JH Motorsports Shift linkage upgrade JH Motorsports shifter stabilizer bushing upgrade JH Motorsports Weighted Black Shift Knob Stewart Warner Gauges (Boost, Fuel Pressure, Oil Pressure and 3.5" 8K rpm Tach) Autometer EGT gauge Innovate Motorsport LM1 Wide Band 10 point roll cage for running quicker then 9.99 in the 1/4 mile EXTERIOR: Painted Lowers Modded S4 Front Bumper Fiber Images Blue/Black Kevlar/CF Vented Hood Fiber Images Blue/Black Kevlar/CF Fenders Fiber Images Blue/Black Kevlar/CF Doors Fiber Images CF Euro Trunk |
| All times are GMT -4. The time now is 11:28 AM. |
