Motor removal/Front clip removal
Can someone point me in the direction.. Im going to do a motor swap very soon.
That's pretty general lol. Drain coolant and oil. Bumper off, headlights out, take out top bolts by headlights, take off bumper shocks. Remove radiator and boost hoses. Either just slide front clip to the passenger side or take AC lines off. Undo turbo and all accessories and both manifolds. Jack up motor with wood between jack and oil pan to access the bottom 3 bell housing bolts. Pretty much all there is to it.
5 minute job. 10 tops
Originally Posted by FasterA4ThanUrs
(Post 1257301)
Also can someone point me in the direction of a timing belt how to. Need to know what tools I need and if I can get all the parts at autozone or something? |
Check the DIY forum on here, audiworld.com, or audidiy.com. Don't fool yourself. It's not easy. 10 minutes tops? Lol it's at least twice that. You must be cutting corners.
No the 3 bottom ones are tucked in by the sub frame, so you need to jack up the motor to access them. Plus you need to disconnect a few more things than I mentioned lol, but I was just giving you an idea of what to do. It can easily be done in a day tho if you know your way around the car.
(Post 1257398)
My concern is doing the timing belt. |
OK I found the write ups..Can I get my timing stuff from autozone or advanced?
Originally Posted by 99a4wagon
(Post 1257550)
You don't have to remove the motor for a TB...
Unless im missing something |
