Motor removal/Front clip removal
Old 12-07-2010, 08:10 PM
workoncars's Avatar
Looks like an an insert on the end now that I look at it a little closer. I plan to tap the center hole and use a slide hammer to remove. I will have it machined to fit the flywheel and re-install.
Attached Thumbnails Motor removal/Front clip removal-ebay-004-2-.jpg   Motor removal/Front clip removal-ebay-005-2-.jpg
  #52
Old 12-07-2010, 08:22 PM
99a4wagon's Avatar
Woow that does stick out far. Look at my pics. Mine was only half that. You have to grind down the nose with a different pilot bearing. Read this thread I made.
https://www.audiforums.com/forum/sho...=160359&page=3
These guys helped a lot ..Kudos to them.
  #53
Old 12-10-2010, 07:03 PM
workoncars's Avatar
The insert is finally out. I tried a blind hole bearing puller with a slide hammer, but this did not work. I drilled the insert out to 11/16 and taped the hole with a 3/4-16 tap. Then I used a threaded rod with a nut welded on the end and the impact gun. Came out in 2 seconds.
Attached Thumbnails Motor removal/Front clip removal-audi-001.jpg   Motor removal/Front clip removal-audi-002.jpg   Motor removal/Front clip removal-audi-003.jpg   Motor removal/Front clip removal-audi-004.jpg
twincroft
06-08-2014 04:55 PM
delftvanp
08-14-2012 11:18 AM
Dan_89
01-03-2012 05:31 PM
AUDITONE4
07-20-2011 12:46 PM
crazehaze
10-16-2006 08:33 PM
Quick Reply: Motor removal/Front clip removal
