my front end squeaks
Old 03-05-2004, 10:51 PM
andrewfournier's Avatar
Default my front end squeaks
<FONT face="Times New Roman, Times, serif" color=black size=4>i have a 99 a4 1.8t quatro. i have an anoying squeak or rub coming from the front right side of the car. it dosent sound like a ball joint. more like a rubber on metal sound dosent allways makethe noise but on most days it will. moisture seems to quiet the sound.anyone else having this problem or heard of it and know how to fix it????</FONT>
Old 03-08-2004, 01:45 PM
brrman's Avatar
That is a control arm bushing. Kinda like 2 balloons rubbing together? It will only get worse and there is no way to lube it and stop the noise.
To fix it you need to replace the entire control arm - Audi does not sell the bushings separate because it takes so much work to press them into the arm.
Take it to a Euro car mechanic and be prepared for $300 bill. Its a common problem with the A4. I've had 2 go bad on my 98.5
Old 03-08-2004, 04:39 PM
i got some prices on the control arms the two uppers are 140 a peice and the lower is 320. which do you think it could be if its so comon.
Old 03-08-2004, 07:28 PM
brrman's Avatar
go to www.ecstuning.com
they have a full 8 piece replacement set for $450 or something. Don't buy from the dealer or you will get seriously raped.
There are four arms on each side (in the front). The usual one that goes bad in the front is the lower rear. This tech might help you out...
Tech article
But it's hard to tell which one it is sometimes - look for a busted rubber bushing cover - or have someone press down on the front end of the car (the corner that squeeks) and have your head down to listen. If you happen to have a stethescope (yeah I know... ) you can place it on the arms and see which one sounds louder - thats pretty much how the dealer find out which on it is.
someone might want to sticky this post...
cheers
<edited><editID>brrman</editID><editDate>38054.6887731481</editDate></edited>
Old 03-08-2004, 11:19 PM
im gona use a pair of electric ears from the tech i work with
Old 03-09-2004, 02:17 PM
brrman's Avatar
cool - good idea man. let us all know hat you find out
Old 03-09-2004, 04:25 PM
A4izzy's Avatar
I'm having the exact same problem. Today, they stated the problem along with a thermostat. I'll let you know what the quote is.
Edo
03-20-2015 07:53 AM
A5Pete
03-21-2013 02:06 PM
rpirani4
01-27-2009 01:10 PM
Stone825
10-06-2008 11:25 PM
wildlife9000
11-09-2007 09:58 PM
Quick Reply: my front end squeaks
