N249
Where is it? What does it look like?
I changed my alternator and now I get p1287 - Boost Pressure Control Valve N249: Open Circuit Thanks, Mike |
diverter valve solenoid... think it's under the intake manifold?
Originally Posted by dragonrage
(Post 1144811)
My guess is you broke one of the connections to it. The vacuum ones are fragile, and the electrical one probably is easy to break as well. Open circuit sounds electrical to me.
Code is GONE. I played around with all the plugs.. basically pushing them in tightly... Re-scanned and nothing!
Awesome, thanks guys! Mike |
under the intake manifold closets to the front, you can bypass it btw, just keep it plugged in electronicly and you won't get a code, also plug the vacum ports on it.
And the reason to bypass it would be...?
they cost alot, kinda usless part imo, and mine failed on me. so i just connected my dv directly to the intake manifold.
If they're useless, why would Audi have used them?
