Need to get my oil changed soon, first time.
Old May 13, 2010 | 08:05 PM
Danny510's Avatar
Default Need to get my oil changed soon, first time.
I have a 97 1.8 Quattro. What do i need to do for my oil change? I know i need synthetic and a German filter, anything more specific?
Old May 13, 2010 | 08:12 PM
NickBroderick's Avatar
You don't need synthetic.
Old May 13, 2010 | 08:14 PM
CCA4's Avatar
don't necessarily need a "German" filter, just one that doesn't suck. 5W-40 and a nice filter will do
Danny510's Avatar
What do i need then?
Old May 13, 2010 | 08:29 PM
CCA4's Avatar
if your motor is in pretty good shape you could get away with a blend, but make sure you change it every 3k. You can just go to AutoZone and get a filter designed for your motor, just don't cheap out
Old May 13, 2010 | 09:08 PM
turbo kraut's Avatar
Tech Guru
knowing the sludge issues with audi's why would you guys tell him not to use synthetic oil?
op: use a good synthetic oil, not mobile, not royal purple, 0-40, 0-30, 5-30 and a good filter... like cca said change it every 3-4k(at most).... if this is your dd... i know people say you can wait 5-10k.... they are playing with fire
Old May 13, 2010 | 09:11 PM
CCA4's Avatar
I didn't tell him NOT to use a synthetic...
I was just sayin that if his motor is in good shape and cost is an issue, you can get away with a blend as long as you change it religiously every 3k. I use Mobil-1 full syn and change it every 3k
Old May 13, 2010 | 09:33 PM
Tech Guru
he has a '97... the motor isn't in good shape....lol
and mobile 1 is not a true synthetic... you realize that right, it is catagory 3... to be a true syn you have to be cat 4 or better
they still say syn, cause they do fit the syn classification, but not like penzoil or the other cat 4 oils, i used it in my car this time, but it was right after my turbo upgrade, next time will not be mobile
Old May 13, 2010 | 10:00 PM
CCA4's Avatar
LOL hey! easy on the 97's
I didn't realize "Mobile-1 Full Synthetic" didn't count as a synthetic, I'll have to look into it a little more. I've been thinking about switching to one of those "high mileage" synthetics like Castrol, whatcha know about them?
Old May 13, 2010 | 10:09 PM
Tech Guru
i was using penzoil euro it is made specifically to meet the requirements put out by the germans for the newer motors
