Need help with ABS system codes
Old Mar 7, 2009 | 06:14 PM
jostojic's Avatar
Default Need help with ABS system codes
I just bought a 2000 A4 quattro. The ABS light was on when I bought it. Vag has no trouble communicating with the control module, but I get these codes:
On Controller 01:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
On Controller 03:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
30-00 - Open or Short to B+
00285 - ABS Wheel Speed Sensor: Front Right (G45)
35-00 - -
00647 - ABS-TICS / Engine: Electrical Connection 2
35-00 - -
I pulled off the ABS sensor on both passenger side wheels and cleaned them. The front right (G45) code went away, but the rest stayed. Reading some other forums, people said to check the connection of the module under the rear seat (which I think controls the ESP). I had a 97 A4 a while back and I remember that module. This car doesn't seem to have it though. Does that mean that this car doesn't have ESP? Anyhow, what should I try next?
Old Mar 7, 2009 | 10:19 PM
auditech79's Avatar
The first code usually has to do with the MAF sensor, as strange as that sounds. It gives a direct signal to the ABS control module for some damn reason and causes that fault code when it goes wacky. I would get some MAF cleaner and give it a good cleaning and see if that code goes away.
As for the ABS wheel speed sensors, you need to monitor the wheel speeds using the vag com in the brake control module. I believe its between data block 1-10. Just scroll down until you see the four wheel speeds. Drive the car, if they don't all don't read exactly the same you have a bad sensor.
Old Mar 8, 2009 | 11:21 AM
brrman's Avatar
I got the 18014 code when my ABS module was on the way out. Your brake warning light flashing by any chance?
Old Mar 8, 2009 | 11:49 AM
CRAZYHAWK's Avatar
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 00287 - ABS Wheel Speed Sensor Rear Right (G44)
1.1 00287 - ABS Wheel Speed Sensor Rear Right (G44): Signal Outside Specifications
1.2 00287 - ABS Wheel Speed Sensor Rear Right (G44): Electrical Fault in Circuit
1.2.1 Possible Causes
1.2.2 Possible Solutions
1.3 00285 - ABS Wheel Speed Sensor Rear Right (G44): Mechanical Malfunction
1.3.1 Possible Causes
1.3.2 Possible Solutions
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
ABS Wheel Speed Sensor Rear Right (G44) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
Check ABS Wheel Speed Sensor Rear Right (G44)
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Rear Right (G44) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
Possible Solutions
Check ABS Wheel Speed Sensor Rear Right (G44) Installation
Retrieved from "http://wiki.ross-tech.com/index.php/00287"
Old Mar 8, 2009 | 11:59 AM
jostojic's Avatar
No, the brake warning light doesn't flash, and I have no problem getting VAG to communicate with the ABS Controller, so I hope it isn't on its' way out.
Old Mar 19, 2009 | 12:04 PM
jostojic's Avatar
Default Finally hooked up to Vag while driving...
So I finally hooked up to my VAG while driving. I get a wheel speed reading on 2 of the tires (#1 and #3) but nothing on the other two. Also, the VAG freezes once the wheel speed reaches 21 km/h. Any ideas?
Old Mar 19, 2009 | 12:08 PM
rayveedub's Avatar
i would start by replcaing the speed sensors in question. look at the abs rig also to be sure there is no damage there.
Sonita
May 3, 2015 05:58 AM
ahatton917
Feb 13, 2014 10:09 PM
Polo2ya
Jan 10, 2014 08:33 PM
mathewsmith
Nov 19, 2010 02:22 AM
Datapro
May 28, 2009 09:22 AM
