need help with locks
Old Mar 15, 2010 | 08:17 PM
euroimport88's Avatar
Default need help with locks
i have a 96 a4 2.8 fwd every time i lock the car only the diver side door locks, then the pump in the trunck will run fo about 45 sec. i have no idea what it can be
Old Mar 15, 2010 | 09:13 PM
airguard350's Avatar
Tech Guru
Vacuum leak? We do have vacuum locks ya know.
Old Mar 16, 2010 | 11:36 AM
Mike-2ptzero's Avatar
If the pump keeps running there is a leak in the lines.
Old Mar 16, 2010 | 09:53 PM
is there any easy ways to find the leak
Old Mar 16, 2010 | 10:08 PM
CCA4's Avatar
unfortunately, me thinks no. as you might guess, all of the lines are hidden so finding the leak won't be easy. i'd suggest starting back at the pump and working your way forward. also for the record, the pump running that long will store a code that you'll only be able to clear with VAG-com.
Old Mar 17, 2010 | 08:09 PM
i found the leak it was my rear door lock, the line just popped off, works like it used to thanks
Sidewayzracer
Jun 13, 2011 07:38 PM
roman_pushkin
Jan 25, 2009 02:24 AM
alxjhn
Jun 8, 2008 01:36 PM
d_maniac
Jun 14, 2006 09:25 PM
TheHolyGhost
Apr 3, 2006 04:46 PM
