Need New Headlights for Audi A4 97
Hey guys, I want to replace my current headlights because it makes the car look old. What do you guys have? Ist it possible to put headlights that are from later years such as 99 to 01. I went to a headlight shop and they showed me some 99's A4 headlights and I saw that new new headlights are not curved in the corner like my current headlights. Seriously I want to change them because they are kind of yellow already.
You can but it takes some slight modifications. You'd have to trim the fenders on the inside and I think you have to do some wiring as well.
....1+^^^ or you can get this http://www.parts4euro.com/DCShop/ind...cPath=2_27_109 it's up to you.
I have depo ecodes on mine and I think they're the best looking for the money. the light output is good especially if you add hid's
http://cgi.ebay.com/ebaymotors/00-01...Q5fAccessories if you like the amber corners like the american 99-01 headlights, they shouldn't be hard to find used. the easiest way to install either of those is if you switch connectors with a 99-01 a4 (also pretty easy to find used) if you were thinking about having that headlight shop swap them for you, it's easy enough to do yourself. to take the the stock two piece headlights out, all you have to do is undo the top bolts, unclip the turn signals from the top and remove them and then there's one last bolt on the sides that you can get at after the turn signals are out. cut and solder in the new connectors and connect them to the new headlights there are plenty of threads about different headlights and pictured installation new taillights will also make the car look a lot newer |
Thank you guys.
5 Attachment(s)
here is what the Angel eyes look like installed,so you can see if you want this kind,i just got my Angel eye lights installed on my B5 today,i want to get HID's that light blue,anyone know what kind is that? what's the wattage? and is it H7 or H8? i don't know which HID lights blue. :confused: I had to rewire them,as they are plug n play for Audi A4 1998 B5's.
Thanks,i can't tell much of a difference from most of them but i think 14000 is blue? :)
