New problem with P0171 code
Old Sep 23, 2009 | 09:12 PM
flipflop's Avatar
Default New problem with P0171 code
Okay guys I received this code a couple weeks back and I changed the vacuum leaks, cleaned the MAF, and swapped out a bad 02 sensor. The code went away then magically appeared again. Same code but now, car has lost a ton of acceleration, has bad fuel consumption, and now leaks oil around the manifold. Oh and the dipstick is drenched in oil and abnormal amount. What could this be? Any help would be appreciated thanks
Old Sep 23, 2009 | 09:29 PM
pullacowonaski's Avatar
it could be that one vac line that goes over you manifold could be clogged and making your seals on your valve cover(s) bad
Old Sep 23, 2009 | 10:00 PM
flipflop's Avatar
I had it diagnosed by a local place and they found two bad vacuum leaks and they fixed them. They did a smoke test too.
AudiZD
Jul 6, 2013 01:14 PM
zeca
Feb 25, 2010 12:15 PM
A4Ash
Dec 9, 2009 12:09 PM
llopez5
May 10, 2007 09:35 AM
jpez
Dec 19, 2005 05:16 AM
