no boost?
Old May 13, 2009 | 11:02 AM
AutoUnionFan's Avatar
no CEL does not indicate no codes
it could be the DV or possibly the wastegate valve.
If its a boost leak it must be pretty big and would be easy to find with the tennis ball method.
Old May 13, 2009 | 02:10 PM
Audacity's Avatar
um. i don't have a vagcom i could probably get it scanned. i checked all the lines. no visible damage to any of them. im not sure how to go about the tennisball thing and would you be able to tell if the dv went bad?
Old May 13, 2009 | 02:57 PM
the DV is the most likely cuplrit. You can check it by removing it and checking for leaks. The DV is opened by the vacuum line. To ckeck it, you need to figure out a way to keep it closed, then see if air will leak passed the seal. Since your boost is extremely low, the leak on the DV should be severe. A new DV (710n) will cost ~$40 and the Forge 007 is ~$100. The Forge DV can be taken apart, cleaned, and examined. Most chip manufacturers recommend upgrading the DV, so repacing your DV even if its not broken is not a bad idea.
The tennis ball method can be found at audiDIY.com
http://www.audidiy.com/b5a4phps/b5a4...percharger.php
It is a very useful method for determining the location of a boost leak. It basically invloves putting a tennis ball in the tubo inlet pipe. The tennis ball has a hole on either side and compressed air is forced into the TIP (~15psi max). Charge the system for few seconds a listen for leaks. It helped me resolve an issue that I had and is easy to do.
If you can get the car scanned for free at a local car parts store, it should reveal some fault codes that are associated with your boost issue.
Old May 13, 2009 | 06:51 PM
Audacity's Avatar
thanks i've been meaning to replace it i guess i might as well now. probably go with the 007 anyone know anything about the splitter? and ill go to the local auto zone tomorrow and get her scanned i think they do it for free.
Old May 13, 2009 | 11:52 PM
Audacity's Avatar
if the dv or anything that went bad would i still hear it spool up? cause i don't hear anything.
Old May 18, 2009 | 07:32 PM
the wastegate valve controls the flow of exhuast gas across the exhuast turbine. If it fails, the turbo may not spool up.
Old May 18, 2009 | 10:22 PM
Audacity's Avatar
referr to my other post. p1136? thats the code that was read.
Old May 19, 2009 | 10:47 AM
  #18
p1136 means the car is running lean. Cleaning the MAF is a good place to start. It could be triggering your car to go into limp mode or something. I would also check for boost leaks while your at it.
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
