No crank no start 1.8t
No crank no start, ignition switch was replaced. Jumping it didnt work, but push starting it and letting the clutch out works and runs totally fine. Tried jumping the clutch cancel switch as well and still no luck (thought of this because the led screen reads "engage clutch to start engine"). Anything else I should try before I give in and get the starter tested/replaced? Heard something about a camshaft position sensor but would assume that we be related to a crank no start issue. Honestly don't understand enough about the subject and would love some input.
No crank usually is just ignition switch, clutch switch, starter, or wiring in-between.
One easy test for you could be to check voltage at the starter solenoid while trying to crank the engine. If you see voltage, then there's a good chance it's the starter/solenoid. If not, then look further upstream.
zore
08-13-2016 11:46 AM
jgm7507
11-28-2007 06:37 PM
Shizzle
04-07-2007 08:31 PM
