No hazards or indicators!!!!
Hi new to this. I have a 98 Audi A4 2.8 V6 Quattro and i have no indicators or hazard lights..... Any ideas.... appoligise if been asked before but been searching for hours and cant find answer :(.... Thanks for your help....
Replace the hazard switch. The relay for both is built into it.
Originally Posted by audiA4beast
(Post 1243007)
it's not the fuses. it's exactly what devil said
Originally Posted by hiwords
(Post 1243125)
There's always a chance it's a fuse. Hiwords meant it as in, before posting about the problem, most of us would expect fuses had been checked. And further, this is a documented and known failure on these cars. You can absolutely count on replacing that switch a couple times during your ownership. Playing the overwhelming odds, and absent any info regaring him screwing with his wiring, it's pretty safe to just go right in and change the switch to fix it.
and actually i saw a thread a little while back about taking it out and cleaning the relays with a screw driver and some sort of electrical parts cleaner and it worked. to get the thing out i used a paper clip and just put it in right above the relay and pulled gently til it came out.
hey guys thanks for getting back to me..... appoligise for getting back so late.... turned out that i had blown two fuses and also the relay was knackered!!!!!! but after that went down hill. fan belt snapped and then found out car had not been serviced in ages like the service book has said and then my central locking f**ked up. all fixed now i hope..... thanks again for your assistance....
How do you access relay for replacement?
It's the orange triangle button on your center dash. Really easy replace on the 99.5+ not hard on the 99-
