no power steering
Open your power steering fluid reservoir to make sure that's engine oil. If the reservoir is full and the belt is intact like HB said, then my bets would be on the pump itself.
Unless there is a possibility that an electronic malfunction caused the power steering to fail? I doubt it. Just a thought.
There are no electronic controls for the power steering on the B5.
I have a power steering leak as we speak and I just spent 15 bucks for a liter of Pentosin or however it is spelt. So yes, I know its not engine oil.
It is good that you know to use Pentosin CHF11.S for your fluid as any other fluid will eventually attack the seals and other non-metallic components.
Most of the time, the rack end seals leak requiring the rack to be exchanged for a unit that has been overhauled. The reservoir can also seep causing loss of fluid.
