offsets for my 19
I planning on get some 19x8.5 i need to know if i should run the 0ffset of 20 or 35 which will be better in the end ? some offset from the guys with 19s would help also thnx
Are you lowered? What tire size are you planning on
I ran 19X9.5 et. 35 for fronts before and they sit flushed to the fenders. Of course I had to run stretched tires to prevent rubbing as I am lowered.
Good luck. |
i was planning on running 19 8.5 with 235 or 245 not lowered but i will be
Opss..
I meant 19X8.5 front. Sorry! I ran 19X8.5 with 225/35/19 Falkens. They were a bit stretched as I am lowered. If you plan on lowering, I would suggest to run 225. I'm running 225 and I would occasionally rub even with the slight stretched. I would imagine 235 would be worse if you are lowered. |
well just purchased my rims today should have them in a week or so pretty pumped thanks guys for your help
Congratulations!
Any preview of what the wheels are? ;) Can't wait to see them on the car. |
1 Attachment(s)
here they are, i'm planning on them roll the way they are at first then eventual going to paint them a flat color maybye a flat black lip or also tossing around a idea or red or flat white
