open thermostat-leaking water pump
Old Apr 15, 2010 | 01:42 PM
hahaha251251's Avatar
Member
Default open thermostat-leaking water pump
my 96 b5 a4q has 145k on it and its thermostat is stuck open, which has begun to make the water pump leak coolant. a lot. the parts to fix the car and give it the "80k service" are around $250. i hear the doing the timing belt, water pump, etc. is a royal pain and worth taking it in to have the service done. the other day, however, i heard that a4's with 12v are a lot easier to do the service on. so heres what i cant really decide- i can wait a month and a half and fix it myself (all the tools that i would need are at a different house that i do not have access to at the moment), or take it in now and pay for an easier job to be done. what route do you guys think i should take based on the fact that the car is my daily driver and bleeding coolant everywhere?
Old Apr 15, 2010 | 03:26 PM
briesa4's Avatar
Do the whole service... your going to need to do it anyways its worth it i own the 12V and it seems and sounds easy to change it all at once
Old Apr 15, 2010 | 03:35 PM
dragonrage's Avatar
Note: stuck open thermostat does not cause leaks. Separate issues.
Old Apr 15, 2010 | 04:07 PM
briesa4's Avatar
^^ correct and +1 when you replace ur tb ur water pump will need to be replaced as well!
rex2001
S6
Feb 16, 2014 12:19 PM
sstph21
Aug 8, 2013 12:52 AM
flipkid
May 27, 2013 11:57 PM
brrman
Mar 10, 2009 02:40 PM
96audia4
Aug 23, 2007 12:14 PM
