over heating
Old Aug 5, 2008 | 08:53 AM
perm2008's Avatar
Default over heating
i just got an audi a4 1.8t. i love this car
but the engine gets really hot really fast. and stays really hot for a long time also the temperature gauge doesnt work. what could be a source of all the heat and how can that be fixed as well as the gauge?
Old Aug 5, 2008 | 09:45 AM
Tweaked's Avatar
Water pump, thermostat, and/or engine coolant temperature sensor are common issues with 1.8Ts.
How do you know that the engine gets really hot if the temp. gauge doesn't work?
Old Aug 5, 2008 | 10:30 AM
perm2008's Avatar
cuz since i just got the car i drove it to my uncles house and popped the hood to show him and it was burning up. and he only lives less then 5 minutes away
Old Aug 5, 2008 | 11:28 AM
blue2.8a4's Avatar
The engines themselves run pretty hot in general, so the diagnosis might not be correct. Has it leaked any coolant? That will be a pretty tell tale sign that the H20 pump is leaking and could be the culprit. You should replace the coolant thermostat so that you can see how hot it is actually running.
Old Aug 5, 2008 | 02:06 PM
aRIf's Avatar
we can't help it because our cars are HOT!
as long as temp gauge does not pass the 1/2 way, then you're ok.
go to the loca dealer and buy a temp sensor. It is dead cheap! Don't risk it.
Old Aug 6, 2008 | 10:10 AM
Tweaked's Avatar
Fix the temp gauge as see how it's actually running. Stop driving it until you do.
marf
Dec 13, 2012 12:12 PM
vmjacintosanchez
Sep 21, 2011 03:06 PM
kashmiriomar
Nov 8, 2010 01:44 PM
Stolzer Vater
Jun 11, 2007 05:16 PM
99AudiA4q
Dec 10, 2004 10:54 PM
