overly high rpms in 5th?
Old Jul 9, 2010 | 12:07 AM
edepaolo's Avatar
Default overly high rpms in 5th?
I was on the highway today, tossed it into 5th, and was cruising at ~60 mph when I noticed I was at 3k rpms, seemed a bit high to me. That normal?
Old Jul 9, 2010 | 12:22 AM
pbrules10's Avatar
I had made a thread on the exact same thing about 2 days ago. From the responses I got, this is normal for our cars.
Old Jul 9, 2010 | 02:43 AM
Tourbo24's Avatar
that really sucks for you 1.8t guys, i can go 80mph at 3k rpms
Old Jul 9, 2010 | 10:45 AM
McGovs2.7TB5's Avatar
Def normal. At 80mph I'm at about 3400rpm
Old Jul 9, 2010 | 11:32 AM
BrianJanice's Avatar
It's weird, because in my 5spd I run at 3k @ 60mph, but in my automatic I run at 2.5k @ 60mph.
They must have different gear ratios...
Old Jul 9, 2010 | 01:03 PM
ImTheDevil's Avatar
They do.
Old Jul 9, 2010 | 02:22 PM
screamin demons's Avatar
Ya i'm not a big fan of the manual for that. I went from the Tiptronic where i could do 75 at 3k and get good gas mileage to the manual that goes 65 at 3k....
Old Jul 9, 2010 | 02:32 PM
choppedelight's Avatar
they have different ratios because the torque converter does just that. you have around the same amount of torque at 2.5k as a direct drive transmission has at 3k.
Old Jul 9, 2010 | 02:37 PM
Mike-2ptzero's Avatar
Very normal for a heavy 4 cylinder car. Lower RPMS doesn't mean your going to be getting better gas mileage since it will take more throttle to keep it at fwy speeds.
3500-4000 rpm during fwy speed is not a big deal for a engine that redlines at 7k. Some of the older Audi cars had a gear setup that put the rpms even higher since it had a 4.11 final drive with the same 5th gear ratio.
Old Jul 9, 2010 | 02:41 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I was going to say, the RPMs alone are not the determining factor for your gas mileage. Many other factors at play here.
