P0302 Code CAR Wont START!!
Car was bogging couple days ago but now wont start at all...
Changed Fuel Pump and filter. I left the fuel pump line disconected and no fuel is coming out when crankin but pump is running? Ive heard it could be the icm and the coil packs but the coil packs are good... PLEASE HELP!!!!! If you can call me with any help it would be greatly apprecitated : ALEX - 647 285 9470 |
RE: P0302 Code CAR Wont START!!
Cyl.4 Misfire Detected that is your code im betting my money on the spark controll mod its located on the intake about 400 from the stealer ship how do you no its not the coil packs
my bad cyl 2 missfire:D
If you have an ignition control module, replace it.
How long since you replaced your spark plugs?
Josh |
I changed the icm spark plugs and moved coil pack over to see if it would throw a differnt code and still cyl. number 2. the fuel pump is not sending fuel maybe no power to fuel pump. the relay clicking and the fuse is ok... i dont no wat i couldbe im goiing nuts guys please hellpp....
did you clear the codes before you rescanned it after moving the coilpacks around? Might be time for a compression test.
josh |
