P1296 Cooling system Malfunction
Old May 1, 2013 | 06:04 PM
ll Jreal ll's Avatar
Default P1296 Cooling system Malfunction
I have a 2000 Audi A4 with a 2.8l. I keep getting a P1296 code. The odd thing is the temp gauge works normal, and the MIL will come on and off randomly. I'm not thinking it is a thermostat being as the timing belt, WP and thermostat was just done about 8 months ago. Not even 5k miles have been put on since then. I'm leaning towards the ECT being the problem. Just looking for any ideas before I dig into this. Thanks.
Old May 1, 2013 | 07:25 PM
CryptoStorm's Avatar
Coolant temp sensor.. It has 2 outputs: 1 for the gauge 1 for the ecu
Old May 2, 2013 | 02:02 PM
jeckel20003's Avatar
Check this out. The "Special Notes" may be useful.
Old May 9, 2013 | 01:18 PM
thanks jeckle, I checked the freeze frame, said it was the sensor, replaced it and now it works great. Much appreciated
Old May 19, 2014 | 12:23 AM
boettger1's Avatar
I've got exactly the same problem on my 2001 but I'm not seeing any freeze frame data. I don't see the check boxes that you're supposed to see here:
Ross-Tech: VCDS Tour: Fault Codes
Did your freeze frame data show up like this? If not where / how did you find it?
joeyt56
Nov 24, 2010 12:42 PM
cwkinney
Jan 16, 2010 10:05 PM
taz4444
Nov 22, 2009 03:50 PM
dljking
Nov 30, 2007 02:20 PM
snowbdr04
Oct 4, 2007 05:55 PM
