people with forge splitter dv
Old Aug 24, 2008 | 04:32 PM
Jc61990's Avatar
Default people with forge splitter dv
what do u recommend having it at, harder or softer, right now mines softer so the BOV is really loud, i just replaced my vac hose so i decided to pull off my dv and grease it. while its off wondering what you peoples would recommend having the spring at. kthx
Old Aug 24, 2008 | 09:11 PM
Jc61990's Avatar
bump....
Old Aug 25, 2008 | 10:46 AM
Mike-2ptzero's Avatar
Changing the spring tension isn't going to make it louder or softer. It just changes how much vacuum the valve needs to keep it open. Best thing to do is to adjust the spring tension to the point so the BOV is just closed at idle. This way it is closed during idle but still needs the least amount of vacuum to open it all the way, if you make it too tight the valve will not open quick enough and this can cause damage to your turbo from surging/cavitation.
I have ran both the GFB hybrid and the GFB FX Stealth, the Forge is basically just a copy of the GFB valves.
Old Aug 25, 2008 | 11:13 AM
onepoint8tee's Avatar
I thought he splitter is designed to always be closed at idle. 10-15 clicks from clockwise is what me and a few others think works well for spring tension.
SunnyShaida
Jan 17, 2009 08:58 PM
czabelin
Aug 30, 2008 04:04 PM
vegastt
Sep 4, 2007 12:18 AM
andrew.bator
Jun 16, 2007 12:35 AM
Mya4T
Apr 25, 2007 02:19 AM
