please help
Old Apr 22, 2008 | 01:54 AM
B5Bobby's Avatar
Default please help
i need to get my tranny fluid changed and dont want to spend "$312.50" for it.
wat is my cheapest solution?
THANKS!
Old Apr 22, 2008 | 02:09 AM
SAudi's Avatar
Default RE: please help
firstly try the search feature but here the DIY
https://www.audiforums.com/m_156758/tm.htm
you will need a special tool to get the drain plug off, it cost maybe $25 and a 17mm hex socket. finally about 3 quarts of your tranny fluid of choice. might i suggest GM synchromesh if you got noisy synchros othewise mobil1 75w90 or if you really push it 75w140 or royal purple. overall all cost will be around $50
Old Apr 22, 2008 | 02:21 AM
B5Bobby's Avatar
thanks for the link
this DIY was for a 2.8, does the 1.8 take 3 quarts exactly as well?
Old Apr 22, 2008 | 02:48 AM
SAudi's Avatar
yes the both trannys take same amount of oil.
Old Apr 22, 2008 | 08:30 AM
01AudiA4's Avatar
I need to do this. When about should you change the tranny Fluid?(milage)
Old Apr 22, 2008 | 10:08 AM
hiwords's Avatar
it's lifetime............ j/k j/k but that's what the dealershit tells ppl. i'd change it every timing belt change
