AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   possible fuel leak? (https://www.audiforums.com/forum/b5-models-69/possible-fuel-leak-200546/)
JoshuaMixon Oct 5, 2013 10:06 AM
possible fuel leak?
When I start up I have to keep on the accelerator to keep the engine going. I hear a whistling noise when I have the accelerator pushed nearly full.
The following picture is of a line that when I move it around seems to relieve pressure. I also can smell fuel in the air. Does anyone know what this line is or if it has anything to do with my issue?
I've looked around in a Haynes manual with no luck whatsoever.
http://i1161.photobucket.com/albums/...ps77750287.jpg
bshusted Oct 5, 2013 10:54 AM
The line you have circled is the vacuum supply to the brake booster. A vacuum leak could cause your hard starting issues. Do you have any check engine codes?
JoshuaMixon Oct 6, 2013 07:02 PM
I have been looking for a replacement, but every one i find doesn't share the same curve angle of this one. I have looked on VagCat extensively. anyone know where else to look? My a4 is the AWM model.
Oh and I don't currently have access to an OBD2, i plan on buying one tomorrow. I have had to take my car to auto zone one too many times, but with my Audi's current problem i don't want to drive it anywhere.
JoshuaMixon Oct 6, 2013 07:21 PM
never mind, i continued clicking like crazy until i found one that is exactly like mine. Hopefully this is the answer to my problem, they want $103 for this hose.
mtroxel Oct 6, 2013 07:32 PM
A bit pricey, but it's the factory part.
Audi B5 A4 Quattro V6 30v Braking Master Cylinder ES#248838 Brake Booster Hose - 8D1611931BL
