Power Steering
Old Feb 19, 2008 | 06:33 PM
Kobe Diesel's Avatar
Default Power Steering
Fluid level is normal (hot/cold). Steering is good, no lack of power-assist. Just makes that whining noise we all know of. Car now has 129K miles.I never changed the fluid nor do I know when it was last changed.
Is this as simple asflush/change the fluid
Or is the pump NFG?
TIA
Old Feb 19, 2008 | 11:49 PM
96A4Owner's Avatar
Default RE: Power Steering
First off, where do you live because generally in very cold weather your P.S. will whine regardless of fluid levels/ fluid age. Mine always does and I have brand new fluids it goes away as my car warms up too.
Old Feb 20, 2008 | 11:07 AM
the pump was making noise since Sept. Then I didnt drive the car for 6 months. At this point, it's not temp related and doesnt go away as the fluid heats up with normal driving.
Could it be the fluid is broken down?
Old Feb 20, 2008 | 09:34 PM
Trey25's Avatar
I wouldn't worry if the noise is at or close to full lock. But if its there when just slightly turning the wheel then its probably a failing pump.
Old Feb 20, 2008 | 10:38 PM
96A4Owner's Avatar
how much does it whine when you just barely turn your wheel?
a3turrell
Jan 14, 2012 05:23 AM
sixat6
Aug 17, 2010 06:40 PM
Lastb0isct
Feb 17, 2009 03:15 PM
