Question about Emissions with down pipe
Old Jan 9, 2012 | 10:57 PM
  #21
Brautty's Avatar
Do you need a down pipe to connect to the test pipe? Was planning on just buying the test pipe and taking it to the muffler shop to have them set it up
Old Jan 9, 2012 | 11:45 PM
  #22
MetalMan's Avatar
My exhaust shop didn't want to build a downpipe, and it's understandable considering there's hardly any room to work around the downpipe flange. I'd recommend buying one.
Old Jan 10, 2012 | 07:59 AM
  #23
CCA4's Avatar
You don't NEED a downpipe to run a test pipe, it will just bolt up where your cat used to be. I definitely wouldn't take your car to an exhaust shop to do a test pipe install. First of all, I don't think they can legally do it because it replaces your cat with a piece of open pipe which is illegal.
The easiest way to get the cat/downpipe out is by unbolting the cat from the turbine housing on the turbo, then climb under the car and disconnect the clamp that joins the downpipe to the rest of the exhaust. there's also a bolt holding the downpipe to a bracket. Disconnect the two O2 sensors and you can pull the whole shebang out from the top. Much easier to work with that way.
Old Jan 10, 2012 | 08:55 AM
  #24
bradtyler02's Avatar
First thing, just use the spark plug anti-foulers, they're much cheaper, and an be found at any big box auto parts store.
Second, I have a 2.5" Neuspeed cat-back exhaust, and while the flanges bolted up right, finding the right gasket between the TP and the DP (turbo side was fine) wasn't so easy. I skeptically used some copper spray gasket in a can between the TP and DP. I was surprised, but it worked (for over a year and a half now).
Third, the Test Pipe just replaces the cat, and bolts straight up to the turbo. The Down Pipe goes down from there and connects to the rest of the exhaust.
Lastly, look into getting the rest of the exhaust done in order to really get any gains from installing the TP. If you have a 3 inch TP going into a stock DP, you're still going to be restricted (but not quite as bad).
Hope this helps.
Old Jan 10, 2012 | 09:04 AM
  #25
CCA4's Avatar
That comes with a 2.5" DP right Brad? How do you like it?
Old Jan 10, 2012 | 09:07 AM
  #26
Yeah. I bought it back shortly after I bought the car because the flex pipe got destroyed when I hit a massive pot hole avoid a woman driver on her cell phone. It was the cheapest cat back I could find, and it's 2.5" from the cat back, DP included.
I love it. It's nice and throaty, without being too loud and obnoxious. That, combined with the TP, and APR tune, makes for a deceptively quick car... But it's still not fast enough.
Old Jan 11, 2012 | 12:18 PM
  #27
Brautty's Avatar
Alright sweet guys thanks for the help and advice!
bgt12
Nov 30, 2014 06:51 PM
hartsoe1
Feb 20, 2013 08:27 AM
1998A4Turbo
May 8, 2009 07:29 PM
kraylon
Oct 18, 2008 12:42 AM
babybabi23
Nov 10, 2005 05:24 PM
