question about rust
Old Mar 27, 2008 | 11:28 PM
a4powa's Avatar
Default question about rust
hey im a couple months away from a purchase of a b5 and im really excited
but i live in canada and where i live the cars are way to marked up so im going to another part of the country to buy one
i might be buying from ontario which has a lot of acid rain and uses salt on their roads for the winter
i was just wondering how bad the rust on the cars are???
Old Mar 27, 2008 | 11:37 PM
hiwords's Avatar
Default RE: question about rust
what year is the car and how many miles? the exhaust should be perfectly fine however the brakes and suspension should be rusted pretty well if it's older than 5 years or so
Old Mar 27, 2008 | 11:42 PM
a4powa's Avatar
im not sure the years and miles
im still just shopping around looking on auto trader and such
and im probably going to buy one with around 80,000 miles on it and im hoping a 99.5 or 2000
how much would it cost to fix suspension?
i plan on lowering the car
Old Mar 27, 2008 | 11:52 PM
hiwords's Avatar
it cost around 800-1000 USD to lower the car. something in that range will have quite a bit of rust on it but it shouldn't affect things much.
Old Mar 27, 2008 | 11:57 PM
a4powa's Avatar
is there anyway to replace some of the main things that have rust??
also my buddy did the same thing that i want too do
and he has about a 120,000 miles on it and the turbo is gone so hes replacing it
at what miles do they usualy blow?
Old Mar 28, 2008 | 12:41 AM
beem's Avatar
I would stay away from cars from the eastern provinces if you can, it is very harsh with the salt, acid rain and moisture from the lakes. I bought one that had spent time in Quebec which had rust on the front and rear subframes and suspension components. Importing from the U.S. is not that difficult. They are some of the only parts not galvanizedas far as I can tell. Check around the battery forrust.I bought a 98 2.8 with sport suspension which is lowered about 1"?(not exactly sure)and it slides very controllably on dry pavement. good luck, B.
Old Mar 28, 2008 | 01:36 AM
SAudi's Avatar
overall audi panels are galvanized metal on both sides so rust should be minimal if any. also audi has a 10 rust warranty so... the main that will probably rust are usualy bolts, exhaust and what not, pretty much stuff that common to rust eventually on any car.
Old Mar 28, 2008 | 11:12 PM
a4powa's Avatar
so i wouldnt have to many problems?
i plan on replacing the exhaust as well anyways
Old Mar 30, 2008 | 10:28 AM
01AudiA4's Avatar
It is hard to say, it really is how it was taken care of. Garage kept, if he cleaned it all the time ect.
Old Mar 30, 2008 | 12:34 PM
vgo's Avatar
vgo
im from toronto, and i found my car with 91,xxxkm on it. Body has been well maintained, and no rust. The exhaust doesnt look too bad either. It is true that the frame is galvanized and there is a 10yr warranty.So rust shouldnt really be a problem but it all really depends on how well it waskept. Very hard to find a car under 90km. good luck on your search and you wont be dissappointed.
