question on headlights
Old Oct 17, 2009 | 12:16 AM
vampyre308's Avatar
Default question on headlights
Hi all, new to the forum here and I have a few questions that I can't seem to find the answer to. And yes I have searched the site and googled lol. I have a 1996 A4 B5, and I am looking to replace the stock headlights with after market projectors and HIDs. The fog lights on my A4 are inside of the headlight assembly and i have not been able to find a replacement headlight that also has a spot for the fogs. Do they even make them? and if i cant find one that will have a spot for the fogs and i take them out will this throw off a code? thanks for your help.
later
Old Oct 17, 2009 | 01:09 AM
Andrew149's Avatar
lol those arnt fogs there idk a small flash light haha check this out anyone of these are awasome
http://www.parts4euro.com/DCShop/ind...cPath=2_27_109
Old Oct 17, 2009 | 12:18 PM
CCA4's Avatar
They are fog lights. Before the facelift in 99.5, the fog lights were integrated with into the two-piece headlight housing. After, obviously, they were moved to the lower grilles. To my knowledge, no one makes projectors that retain the integrated fog lights. Probably because they would interfere with the projector lense. I've done the 2-piece-to-1-piece conversion on my car, thus losing the fog lights. I capped off the hot leads from the fog lights and just tucked them back into the harness for the time being, it won't throw any codes. Also, for the record, your rear fog light WILL still work.
As for replacements, you can go with the 2-piece DEPO projectors (aka S4 projectors) like ImTheDevil has on his car (check out his garage, there are pics there). Or you can do like me and do the conversion. Little more complicated, but definitely not rocket science. If you'd like more info on that i'll be happy to elaborate.
Old Oct 17, 2009 | 05:31 PM
vampyre308's Avatar
CCA4, thanks a lot for your help. Now I know what to do, time to go order my new headlights
Old Oct 17, 2009 | 05:39 PM
CCA4's Avatar
whatcha gonna get?
Old Oct 17, 2009 | 09:38 PM
tmanley's Avatar
vampyre308...
GOOD Question...in the same boat and reviewing posts to see what the deal is.
Given that.....can we do the post 99.5 fogs into the bottom grill????
Mine are all over as the adjuster plastic is all broken and I need something brighter here in the country so I can play frogger with the deer!!!
which are the ones that i see all over eb*y that same NO modification required?? Those look like a 2pc to one pc conversion.
I will have to look around and see what the options are as you stated above cca4.
Thanks
Old Oct 17, 2009 | 09:43 PM
Mr. Phil's Avatar
i posted a link to an ebay listing not too long ago... there is fog light pieces that fit directly into the pre facelift bumper... or i believe someone said the facelift fog housings also are a direct fit for us pre facelift as well... pick ur poison
Old Oct 18, 2009 | 12:48 AM
vampyre308's Avatar
hey CCA4 I just bought 2 piece black euro projectors made by Helix. here is a link to them with all the stats these are supposed to go in with no problem and no mods. crossing my fingers.
http://cgi.ebay.com/ebaymotors/AUDI-...ht_6016wt_1115
and tmanley I am there with you and was thinking the same thing about relocating the fogs down into the air dam, or bottom of the grill. More research to do and I'll wait for warmer weather to do that. Will keep you posted if you like.
junnjiaa
Mar 16, 2014 12:00 AM
TheoChen
B8 Models
Dec 31, 2010 01:10 PM
MichaelThePsycho
B8 Models
Jun 16, 2009 10:42 AM
Black_97 A4
Jun 26, 2007 10:19 PM
CincyA6
Jun 23, 2006 05:06 AM
