radiator hose clip part number? A4B51.8
Sorry to bomb the list but a searches looking for parts diagrams didn't find the right ones.
I'm doing a timing belt change on a 2000 A4 AWM 1.8T motor. As I live in the Land of Salt and Corrosion, there are always minor parts that break while getting to the ones that count.
The metal clips holding the radiator hoses broke; at least the lower one did. Plus there are other parts related I"m having trouble finding. So if anyone has a decent set of parts diagrams for these areas, and can point me in the right direction, I need:
1) radiator hose clips and o-rings if available
2) short hose to tee for the headlight washer system
3) o-rings for the washer tee fitting
4) alternator duct-mine is missing
5) fan shroud wiring clips- mine are rusted beyond use
thanks,
Sean
thanks,
Sean
This is a great website for part diagrams. Audi Parts - Authentic OEM Audi Parts direct from Jim Ellis Audi Parts | Jim Ellis Audi Parts
radiator hose o-ring and clip part number?
I'm just trying to see whether that's the situation I'm in.
found clip part number
C-Clip Retainer for Radiator Hoses - JH Motorsports Inc. - -- JHM. Shifting you to the next level
1J0 121 142 $2.75 at jhmotorsports.com They don't stock the o-rings, so I'll measure them and the grooves I guess and report back.
o-ring for upper/lower radiator hoses
After some searching, the o-ring is NBR material (nitrile buna rubber) with 4mm cross section and 32mm i.d.
Available at
4mm x 32mm Buna-N 70 Metric O-rings [N4.00X032] : The O-ring Store, Online distributor of O-rings, Seals, and Kits, We make getting your O-rings easy!
Available at
DiscoJaker
12-02-2020 02:16 AM
Falo
01-11-2013 04:19 PM
