radio removal help
so I got some radio removal keys off ebay. I stuck them in each slot... now what?
I've tried pulling, pushing, wiggling... ***** not coming out. I dont want to break anything... how far should I be sticking these keys in? How easy does the radio come out? Do I push up/down or sideways once the keys are in?
you need 4 keys. they go all the way in until the rounded parted. you should here a click sound. then you pull the left side a tiny bit and then the right side then pull the bottom or top and the whole thing should come out
either a) the keys arent in far enough or b) the clips are broken youll know if theyre holding they go pretty far in and then wont want to come out easily in which case u just have to wiggle it around a little or if theyre broken they go in kinda and dont hold anything which is the problem i had i ended up just breaking off the two sides and prying the clips because i took it to an audio shop and they quoted me $200 to take the whole dash apart to get it out
