Re enable airbag
On my A4 B5 model the airbag was disabled by audi , when I connect cag com it comes up with passenger airbag is disabled , Using vag com how do I re enable the airbag???? ie what code do I change ????
It's on there I checked. You can find it too. Search for "airbag deactivation." Click on either Audi A4 (8D) entries...only two come up. It's at the bottom of both.
Here is how you reactivate the passenger airbag.
Use the VAG-COM adaptation function to reset Channel 01 of the airbag controller to 0. It should be 1 if the airbag is off.
