Rear Driver's side window issues.
Here's a video, excuse the lame narration.
Pretty much when I pull up and hold the button/lever whatever you wanna call it for the rear window, it goes up to a point, stops like its sensed resistance (the window is programmed for pinch protection I believe) and then goes down. But, if I inch it up by pulling up the button in short bursts, it makes it to the top. When using the central locks from the outside (rolling up all windows with key) it goes up no prob.
Any help/ideas?
Any help/ideas?
You could always unhook the battery for awhile. When you reconnect it, you'll have to reprogram your one-touch windows. Maybe by blanking them out and resetting them, you'll clear the issue. It's easy enough to try it. Be sure you have your radio code though.
