Red Antifreeze
Old Nov 3, 2008 | 12:01 AM
  #31
onepoint8tee's Avatar
Originally Posted by anmagro
If my coolent starts to freeze what happens exactly?
Water would stop circulating which means it will not make it to the radiator to get cooled which= overheat. Water circulates through internal pockets/canals/pathways in the engine block/head to absorb heat and gets pumped/circulated to the radiator to cool.
Old Nov 3, 2008 | 12:48 AM
  #32
hiwords's Avatar
i doubt your coolant will freeze lol. even if it does, you might get a little overheating but as soon as the icing melts from the heat the engine produces, you'll be fine again. there's no such thing as a 50/70 mix lol. you mean 30/70 right? just let some of the coolant out and put in more straight G12 if you have any left. if not, i really think you should be fine since you're only in NY. now if you lived in Alaska, i wouldn't be saying that haha
Old Nov 3, 2008 | 12:58 AM
  #33
Every Audi tech I know (I know a few) uses a 50/50 mix regardless of what the bottle says. If you ran straight water then you'd have something to worry about. Even a very very weak antifreeze mix would keep the water from freezing. The main reason you need a stronger than necessary mix is to keep the radiator from corroding. G12 is great stuff. When is the last time you heard someone had to replace their radiator?
Old Nov 3, 2008 | 10:42 AM
  #34
CRAZYHAWK's Avatar
50/50 freezes at -40 F. 100% antifreeze at +8 F.
The universal yellow antifreeze allows me to add
if necessary at any gas station.
A4 Neil
Oct 10, 2011 03:39 AM
Tullybeagles
Dec 7, 2010 03:37 PM
LeAudi19
Jul 27, 2008 06:37 PM
ballswell
Nov 26, 2007 02:29 PM
blast
Mar 12, 2005 11:20 PM
