The right chip
Old Feb 13, 2008 | 07:17 PM
A4speed's Avatar
Default RE: The right chip
Autobarn Motorsports Inc.
333 w. rand rd.
Mt. Prospect, IL 60056
Telephone: 847-392-6300
for more GIAC dealers go to:
http://www.giacusa.com/dealermap/
Old Feb 14, 2008 | 09:00 AM
patty AT forge's Avatar
The 007 comes with springs good for 5-30 psi.
Old Feb 14, 2008 | 09:33 AM
TommyGunns's Avatar
Check the companys web site to find dealers. There should be more than a couple around Chicago, so you won't have to take out our ECU.
Old Feb 14, 2008 | 09:34 AM
TommyGunns's Avatar
I think there is a place around there that sells REVO chips, and the nice thing about REVO is that they let you test drive the chip for several hours for free.
Old Feb 14, 2008 | 11:45 AM
kuku's Avatar
So what should I check for, before installing the chip? Are there any tests for boost leaks I can do myself? Do I need to take the car to a mechanic the get it checked before getting the chip, because my car seems to be in pretty good shape, except one thing I'm not sure about, when I rev the engine, and when I let go the gas pedal, and rpm starts going down I hear some kind of rattle, but it's not noticeable unless I open the window, and it's only when the rpm goes down, when it goes up it's fine.I can't figure where it's coming from, it doesn't sound like it's from the engine tho, sound like some metal shield is touching something and vibrating, I haven't had the chance to research it further because it's freezing cold outside, but I don't want to take it to a mechanic because it's probably something small, it's coming from the passenger side I think, but I'll look at it when it gets warmer. I hope that won't be a problem when I install the chip? or it might be? Any advise on that. And also, should I get the DV installed first, or after I get the chip? Thanks
Old Feb 14, 2008 | 12:00 PM
chaos92287's Avatar
its recommended you do the dv and chip at the same time. you can do the dv first with no problems, but if you do it after, the chip might tear your stock dv. some people have had their stock dv fail the same day as the chip, others have had no problems for months. it all depends on how good of shape the dv is in i guess. i would just do the dv now or when you get the chip.
if you want to check for boost leaks, theres a few links on how-to here- http://www.audidiy.com/b5a4.html
but i wouldn't go through the trouble unless you knew you had one. just get a boost gauge
Old Feb 14, 2008 | 10:04 PM
kuku's Avatar
Allright, 10X everyone for the advice, I'll be getting GIAC soon, made my decision, I'll also get some wheels and I'll take pics, post again to share my experience.
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
ricehead
Nov 4, 2005 10:59 AM
