Rim width
Old Mar 16, 2010 | 07:42 PM
MrEvans86's Avatar
Member
Question Rim width
Does anyone know how wide of rims the a4 will fit without modifying the wheel wells? I thought about a 3 piece offset rim.
Old Mar 16, 2010 | 07:58 PM
hiwords's Avatar
8 with a 36-39mm offset. also depends on what size tires too. 235/40/18 is the largest i've seen people run without rubbing usually. of course each tire is a little different.
Old Mar 16, 2010 | 10:59 PM
ImTheDevil's Avatar
Yep different tire designs have different shoulder curvature. Mine are 19x8 and a +37 offset (+42 offset built into the wheels and I'm using 5mm spacers). The tires clear the suspension and spindles but only by a very small margin. I don't know if I'd go any more than a +38 even on a 225-section tire though just to keep a margin of error.
Old Mar 16, 2010 | 11:04 PM
MetalMan's Avatar
I'm running 19x8 as well, with 235/35/R19 tires. I used to have pretty major fender rubbing issues in the front (lowered on Eibach springs) until I got those fenders rolled. The back is/was perfect.
Not sure what offset the wheels have, I bought the car with this setup.
Old Mar 16, 2010 | 11:32 PM
ImTheDevil's Avatar
I'm also on 235-35ZR19 tires and I'm lowered 2.5" up front and about an inch out back on coilovers, and rolling the fenders is a must. But the offsets above will allow the combination to work. It's tight but it works.
Old Mar 17, 2010 | 01:36 AM
kriptonik's Avatar
18X9's all around.
Rub everyday.
Old Mar 17, 2010 | 03:47 PM
NickBroderick's Avatar
Hahaha Krip, I'd love to see your tires. I'm getting some 17x8.5's soon so I should probably roll my fenders soon.
myslow1
Jan 22, 2009 09:28 PM
warranty225cpe
Dec 18, 2008 06:24 PM
ryanmcell
Jan 20, 2006 10:29 PM
A4_Spooler
Nov 7, 2005 10:53 PM
