RS4 17x7.5 ET43 & tire wear
Old Apr 11, 2009 | 09:49 AM
escyr's Avatar
Default RS4 17x7.5 ET43 & tire wear
I installed a set of OEM RS4 17x7.5 43mm offset wheels & 225/45-17 Avon M550 A/S tires on my 2001 A4 1.8TQ with factory sport suspension and the inside edges of the rear tires wore very fast. The tires were unusable in about 20K miles. From what I understand this is because of the non-adjustable toe on the rear of the B5 A4. I really like the wheels and would like to use them again. What are my options?
Narrower tires...If so, what size?
Kmac adjustable bushing? Are they worth it?
I was told that it was just an alignment issue but I had the car aligned to factory spec when I got the tires. The alignment was not done on a 4-wheel alignment machine, but done on the shop floor with a laser alignment system.
Old Apr 11, 2009 | 10:43 AM
hiwords's Avatar
you need to get an alignment done with the machine. also check your bushings on the CAs
Old Apr 11, 2009 | 01:31 PM
escyr's Avatar
Thanks hiwords, but do I use the stock alignment specs?
Old Apr 14, 2009 | 11:50 AM
escyr's Avatar
Anyone know what alignment specs I need for this tire/wheel combination on my car?
Old Apr 14, 2009 | 12:11 PM
hiwords's Avatar
fireman9585
May 19, 2010 08:25 AM
fireman9585
Jan 24, 2008 04:34 PM
gordond
Jan 20, 2007 06:07 PM
gordond
Jan 20, 2007 05:59 PM
seaurchin99
May 26, 2005 11:39 PM
