SAD :( advice pleaseeee
Old Jan 4, 2013 | 04:03 PM
northwest b5's Avatar
Default SAD :( advice pleaseeee
Hey guys
I recently got my new ecstuning rear license plate frame went to go take off my license plate (which was only held on by 3 screws and a piece of duct tape) and the first screw comes out like nothing. The other two just KEEP SPINNING :0 so frustrating ... now the plate is loose, I don't know what I should do at this point it looks like sh*t.
Help! Thx
Old Jan 4, 2013 | 07:45 PM
planedr65's Avatar
Take a knife or flat tip screw driver and stick it behind the plate right next to the screws, pry out firmly, don't try to rip the plate off. Turn the screws while prying out and they should come right out.
Old Jan 4, 2013 | 07:55 PM
B5 Audi's Avatar
X2.
then run to auto zone and pick up some nice bolts
Old Jan 4, 2013 | 08:18 PM
CCA4's Avatar
Happened to me within the first 5 minutes of owning my car lol. I use double sided 3M tape to hold my plates on now
Old Jan 4, 2013 | 09:06 PM
I also read that I will need some plastic clips or something like that? That hold the screws in place. And I was so pissed lol this plate had to have been on for years, previous owner was a dealer only kind of guy and let some things build up like the drain plugs by the battery. Thanks for the rust
Old Jan 4, 2013 | 09:11 PM
CCA4's Avatar
Yeah mine had fairly large holes in the outer skin of the hatch, then there were little white plastic plugs that clipped into the holes, and the screws that held the plate on bit into the clips instead of the body work.
Old Jan 5, 2013 | 11:54 AM
Dallas09's Avatar
You can also pry back the plate on the left and right edges to expose the two screws that hold the bracket to the actual body of the car. You can remove those and then deal with it off of the car.
Old Jan 5, 2013 | 09:42 PM
Thanks the help everyone, tried the advice on sticking a flathead behind the plate while turning and the first came out like butter, the second ripped out of the hole initially pissed then after contemplating getting a new mount I just CCA4'd my plate haha, it'll do for now until I stumble across one at the junkyard.
Old Jan 6, 2013 | 12:32 PM
kriptonik's Avatar
Now I know to steal your plate when I see you.
Old Jan 6, 2013 | 05:49 PM
02A6Beau's Avatar
but your car is not a wagon......ohhhh.....riiiigghhht
gshultz75
Apr 26, 2013 01:22 PM
purepowerfit
B7 Models
Mar 21, 2008 06:39 PM
euroracersa4
May 3, 2007 05:35 PM
luke30
Sep 27, 2006 01:59 PM
luke30
Sep 27, 2006 01:58 PM
