saw my first 2.8 turbo car
Old Jun 29, 2010 | 08:08 PM
turbo kraut's Avatar
Tech Guru
Default saw my first 2.8 turbo car
ok, saw this while working, if i wasn't in my work truck i would of put a note on the car asking if they wanted to race a "stock" 1.8t.... cause if they are dumb enough to think they got a turbo 2.8 then they would be dumb enough to think i am stock
on a side not, as i was coming home my idle started bouncing, as i pulled onto my street, my car sounded like ****, i started backing in as usual, and heard the dreaded dentist drill.... i about ****, cause i just put in my new turbo..... i backed into the garage and it was louder, i was like wtf...... popped the hood, and i could hear air and the motor was stuttering... i looked around and saw some wires were under my heatshield touching my turbo, fixed that, nothing was melted then i saw there was a hose that should be on the mani not attached, re-attached it and all was back to normal
Old Jun 29, 2010 | 08:30 PM
NickBroderick's Avatar
Maybe the joke is on you and he too has a built car.
Glad to hear the car was an easy fix!
Old Jun 29, 2010 | 08:35 PM
Tech Guru
i doubt it, should of seen the rest of it.......
Old Jun 29, 2010 | 08:38 PM
BrianJanice's Avatar
The 2.7T stroker setup ! oh man you should've asked them to pop the hood.
Old Jun 29, 2010 | 08:44 PM
Hahahaha, I figured.
What else was done to it?
Old Jun 29, 2010 | 09:00 PM
Tech Guru
some janky exhaust tips that use screws to hold them on.....
unless it was a 2.7 swapped a4, that was supposed to look "stock"
if i was in my car i would of knocked on his door
Old Jun 29, 2010 | 09:01 PM
Obviously if you have the 2.7T stroker, you have done the A8/TT brake conversion...
Old Jun 29, 2010 | 09:27 PM
flynnr's Avatar
what sort of line connects to your mani??
ooo intake mani? vac line? just assumed you meant exhaust mani
Old Jun 29, 2010 | 09:51 PM
Tech Guru
yeah, it is the vac line right by the coolant overflow..... it was cause i was running the car too hard.... had to put the dodges in their place, magnum and charger, both v6's but both thought they were the ****..... factory for them is maybe 250 chp.... i have at least that at the wheels
i want to run a hemi
i'd run flyn and his new disco..... and make him wish he had a baby bt...... :P
Old Jun 30, 2010 | 12:52 AM
flynnr's Avatar
lol go get dynod and we can let numbers do the talking yo
