Seats loose
I am still looking for the bracket on driver side.
And figure out what the 2 car connectors on driver side are for (both 2 wire, one large female holes, thick wires, brown and red/blue, one smaller female holes, thin wires, brown and brown/red) are for. Seat has red, green, yellow connectors. Only green is connected.
Passenger side:
Car has green adapter, plugged into green seat connector.
One connector (2 flat/spade, offset) is coming from the seat. No visible other wire coming from floor/car.
Airbag light is on.
Codes:
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D00
Coding: 00127
Shop #: WSC 06334
VCID: 3469E80D2EBD
4 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-10 - Open or Short to Ground - Intermittent
Passenger side:
Airbag light is on.
Codes:
Coding: 00127
Shop #: WSC 06334
VCID: 3469E80D2EBD
4 Faults Found:
The airbag connector is the dangling yellow connector up above in the first set of pics you posted, second to last pic in the batch. Get that one plugged in and you'll lose all the airbag-related lights and codes.
Will do in a few hours. What are the green and red connectors on the seat for? Any one for seat heaters? Car does NOT have green and red connector, just 2x black connectors (both 2 round female pins, one thick gauge, one thin gauge). There IS voltage (I think on the thick gauge one) when I turn on the driver side seat heater switch.
pzp107
Nov 8, 2020 11:28 AM
